Advanced Architectures in LabVIEW - library install error
Recently I have some time to practice LV further, and I want to continue with the Advanced Architectures in LabVIEW online training.
I have downloaded the exercise manual and files from NI.com.
Just at the beginning of the manual, we are asked to install first the "STM API" library under user.lib. (Excercise 2-1 "Evaluating an API design").
This installer throws an error, and it does not install anything.
I have LabVIEW 2014. This online tutorial seems a bit outdated, since the pdf manual talks about LabVIEW 2011.
Is that possible to use the "Advanced Architectures in LabVIEW" self-paced online training with LV 2014?
The error msg does not contain too much hints about problem... (the installer does find the proper LV2014 path)
(3,435 Views)
Accepted by topic author Blokk
Even then, you could just install the latest STM library via VIPM.  It is in the LabVIEW Tools Network.
(3,425 Views)
yep, thanks, I have found the version 3.0.0.6 via VIPM. So I guess I will just follow this practice through the online training, to check always the newest library versions via VIPM.
edit: just FYI, this newer version of STM does not include the "STM Basic Client Example.vi" and "STM Basic Server Example.vi" VIs, which are refered in the pdf course manual.
I think this online training material would require some update from NI...?
(3,406 Views)
