Additional installer
I am using LV2012 64 bit. When creating installer, in additional installer category LabVIEW RTE 2012 SP1 is selected. When testing the installer on the deployment machine it requires to install RTE before proceeding with the application installer. For some reason the RTE does not get installed and have to be done separately on deployment pc?
The other question is when using DAQmx which options in Additional installer should be selected so that it installs DAQmx on deployment pc.
TIA.
(2,623 Views)
Depending on what DAQ you have you may need more, but you will need the NI-DAQmx Core Runtime.  If you have some cRIO DAQmx you will also likely need the NI-RIO item.  Did you do anything with DMMs?  You'll need NI-DMM.  Serial stuff?  NI-VISA Runtime.  Each application will need different additional installers, many times it is trial and error based on the error message you get when you try to run the EXE and are missing some component.
(2,572 Views)
