Addition of 2D array
I need to sum up the output from a detector continuous which takes the form of 2D array. I was trying to do so by using polymorphism and shift register. However, when I put an indicator at the outlet of the addition, no output is given. Why would this happen I have the file attached, and the addition happens in frame one of the outer sequence structure.
Thanks!
Angelia
(2,645 Views)
Actually I realize I only need to initialize the shift register.
(2,637 Views)
Angelia,
I was actually just looking at your code Smiley Very Happy I'm glad you caught it too!
Sam S
(2,609 Views)
