Adding for loop into Waveform chart to output portion of data for every 30 seconds until data finishes
 Good day,
I have so far created a waveform chart but showing all the datas in one go. I'd like to show it some portion of data for every 30 seconds until all data in the spreadsheet is shown.
Detailed:
In the spreadsheet file, the first column will be use as a 'plot' to show the data. Meaning that from 0-128 will be shown for 30 seconds, then the next data of 0-128 will continue to show for 30 seconds until data finishes.
My plan is to use for loop, however failed to do so.
My aim is to show data interval like this https://www.youtube.com/watch?v=kxWUCADgGbA
Your kind assist is appreciated.
Message 1 of 11
(5,480 Views)
Is each file the 128 data points?  Or will your csv be much larger (iecontaining all of the data you want to plot)?
Message 2 of 11
(5,453 Views)
the csv file contains 181 times of the 128 data points. Which means that the waveform chart will loop 181 times of the 128 data points. My aim is to have looping iterations of 128 data points for every 30 seconds, for 181 times.
The attached jpeg is what I got so far, however the data only show the first 128 data points only repetitively.
Message 3 of 11
(5,449 Views)
Please attach the VI, NOT a jpeg image.
You have some fundamental problems. Your wire goes BEHIND the for loop (your lack of tunnels), and your Array Subset is floating over the for loop (notice shadows on your JPEG). This is what it should look like if wired properly.
Message 4 of 11
(5,433 Views)
This is what I've got so far (EEG3 is my testing block before editing EEG 1&2). My aim is to have my waveform chart ran like this https://www.youtube.com/watch?v=kxWUCADgGbA
Message 5 of 11
(5,421 Views)
I know this isn't the question you asked, but I'd like to suggest another approach (based, in part, on the YouTube video you attached).
What I think you want to accomplish is to have the entire waveform scroll (or "jump") across the screen, similar to seeing successive "snapshots" of your data with some subset of points (say 500) being visible at any one time.  Instead of "jump-scrolling", why not consider plotting the points one at a time (all 128 x 181 of them) in a Waveform Chart of 500 points at some rate (say one point every 10 to 100 msec -- the rate determines the rate at which the plot "scrolls")?  You'll see a plot similar to your YouTube example, except instead of "jumping", it will smoothly scroll.
Accomplishing this is very easy.  Create a Waveform Chart.  Open your data file, arrange all of the data in one long array (assumed to be continuously-sampled, i.e. the time difference between all of the points is the same), and feed the array into a For loop via an Indexing Tunnel (the one that turns an Array into individual elements, automatically looping over all of the Array elements).  Put the Chart indicator inside this Array and feed the point into it.  Put a Wait (ms) function inside to slow down the scrolling speed to something that you like.  I presume you know how Waveform Charts work, but you can always right-click the Chart Indicator on the Block Diagram and choose Help to get help.
Message 6 of 11
(5,416 Views)
Accepted by topic author pingping12
1. Since you want your chart updated every 300ms, then you need to move the terminal to be inside of the loop.
2. You need to update which row to start from each iteration.  This is some simple math with the i terminal and the number of samples you want to display.
3. The file you gave us only has 128 samples of 14 channels.  So the loop should only iterate once.  You can do some simple math to determine the number of iterations to perform (total number of samples in the file divided by the number of samples to display).
Message 7 of 11
(5,372 Views)
Thank you all for the solutions. I have read all of them and try to apply it in my own way of understanding.
This is what my progress so far. I do have the graph ran in an interval time manner. However only one channels are shown and I do not think that the steps that I have apply to my blocks are correct. I'm currently still actively finding a solution.
Hope to have a final solution soon
Message 8 of 11
(5,336 Views)
I have tried the proposed solution, here's the outcome. However, not all my 14 channels displaying properly (4 of them displayed straight line, which shouldn't happen with the data provided).
EDIT: I manage to fix 3 of the disfunction straight line charts. Only one of it still left with straight line chart outcome (the very bottom chart).
Message 9 of 11
(5,325 Views)
Looks like a scaling issue.  It is like there is something in the history that is messing up the auto-scaling.  I recommend you go in and manually set the max and min of each of the scales.
Message 10 of 11
(5,321 Views)
