Adding array by shift register generated from IMAQ image to array function
In my programme a 2d-array has been created inside a while loop. I want to add up this 2d array by using shift register within the while loop as long as the loop continues. But it do not work. The output array is simply blank. It would be very helpful if any one knows the solution.
SJ
(3,290 Views)
Accepted by topic author SJphys
Hard to tell without seeing your code.  But I'm guessing you've probably got something like figure 1 here:
You need to either initialise the shift register with an array of the correct size (number 2), or store the array rather than adding it on the first iteration (number 3).  But if all you're doing is adding the arrays together, you might be better off with number 4 which uses the IMAQ Add function.
(3,283 Views)
Thank a lot for your help.
(3,243 Views)
