Adding an offset to a 2D array column value
I am building a search tool for an excel file for a particular cell whose column value has to be offset by the 'column_offset' value from the reference input generated initial coordinates.
Therefore I need to add the 'column_offset' value only to the column data of the array constants (2,1) , (2,4),(2,7) & (2,10).
So , if the 'column_offset' is 2 then the VI should generate the array constants of (2,3),(2,6),(2,9) & (2,12) respectively.
Plain polymorphic addition  adds the 'column_offset' to both the row & column value.
How to add the value only to the column selectively?
Thanks.
(2,795 Views)
I was confusing cluster with array.
The cluster can easily be unbundled & row/column separated.
(2,791 Views)
