Adding additional features to the existing Vi
Hi there,
I am trying to add features like Auto-correlation, Cross-correlation, Frequency domain, Time domain to the existing Advanced Harmonic Analyzer Measurement.vi, I have removed all the input blocks in the while loop for the vi and created blocks with Ni-RFSA which takes input from the Ni-PXI device now I am trying to add the above mentioned features but I have no clue how to start adding features( what blocks i should use, how to add each feature...).
Thanks in advance
sri.
(2,817 Views)
hi,
you can search the function above on this forums, many examples are provided.
as for the blocks the correlation blocks are present in Signal Processing->Signal operation....
regards
(2,809 Views)
Hi Sri,
I was wondering, is there a particular reason that you're using this Advance Harmonic Analyzer Measurement VI? If you're looking for a VI that will acquire from your physical NI-RFSA hardware, then there are plenty of examples for that. You can find them at the folder path Hardware Input and Output»Modular Instruments»NI-RFSA»... in the NI Example Finder (Help»Find Examples).
As for the auto-correlate VI, etc. you can find those in the functions palette that is in the attached image. They lie in the Signal Processing»Signal Operations palette. Have a good one!
Chris W
(2,771 Views)
