Adding a reference for VB application in LabVIEW
I am using a VI that allows me to import Visual Basic code into LabVIEW. It is called LabBasic. However, my Visual Basic code only runs when I add a reference to my project within Visual Basic. Can I do the same thing within LabVIEW?
Thank you.
(2,873 Views)
I'm not sure I understand your question.  The LabBasic home page says that:
Using LabBASIC is just like using any other VI. Source code can be typed into the syntax aware dialog box on the Express VI’s configuration dialog box, or a simple text control or constant can be used and wired to the LabBASIC VI. Values are passed into LabBASIC by bundling elements into a cluster, and then wiring the cluster to the LabBASIC VI. The LabBASIC VI produces a standard LabVIEW Error Cluster that can report on any syntax errors, and also allows the user to output a text string. This string can then be used, cast, split, etc for use by other elements in LabVIEW.
David_B
(2,851 Views)
Hello.
I work on Labview 7.1 and Labbasic doesn't work on it.
Can I find the same tool for my Labview version?
(2,825 Views)
