Adding a picture to excel file using ActiveX
This post in the thread in linked to has a link to the free toolkit and how it looks in labview.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 11 of 21
(2,650 Views)
Thanks.
Message 12 of 21
(2,641 Views)
Paul,
I tried to use for loop for multiple entry as you said, but it gives me error. I tried to put everything in a for loop and still gives me error. And for some reason, it skips every other data entry. Do you know what is the problem? Also, when it gives error, then I am not able to open that specific excel file!! I should open another one (I guess that's because it doesn't close the application due to the error)
I also tried to feed an array to the cell (third file) and it gives me the same error, so if I figure out the problem with the first one, I guess I may not even need to use for loop.
Baran.
Message 13 of 21
(2,637 Views)
Baran,
Pay attention when and how often you open and close a reference.
- References opened outside the for loop must be close after the for loop.
- References opened in the for loop must be closed in the for loop.
Paul
Message 14 of 21
(2,632 Views)
I think I have done that. I closed "_worksheet" and "range" inside the loop and the others outside (in try1 file). Could you save the file compatible with 2009 labview?
Baran.
Message 15 of 21
(2,626 Views)
Message 16 of 21
(2,624 Views)
Thanks. It works now. I just don't understand why the "_worksheet" should be closed outside the loop?
Thanks again.
Message 17 of 21
(2,619 Views)
The Worksheet Reference is opened by using the Invoke Node Sheets/Item (just before the for loop). The reference is only passed through _Worksheet. And the reference is used in each for loop iteration. If you close it in the loop (it happens in the first loop iteration), in the second iteration the _Worksheet/Range/Cell1/Cell2 generates an error because the reference was previously closed.
Message 18 of 21
(2,615 Views)
OK. I see.
Thanks.
Message 19 of 21
(2,607 Views)
Hey,
I am trying to "shift" or move my picture into a certain spot in excel. I am able to move it by typing the right coordinates through the "shapes" box, but its not really efficient and convinient for me.
Is there a way to tell the picture to move into a certain cell instead of adjusting the coordinates using the "Shapes" box??
Message 20 of 21
(2,531 Views)
