Adding Proportional control using NI LabView Control Design Toolkit
I was just wondering is it possible to add a proportional control to your program using the NI Control design toolkit? There is a PID control fuction available, but i just want the P
(4,063 Views)
LC87,
A proprotional controller is equivalent to a multiply, so you could just create a transfer function with Numerator=[Kp] and Denominator=[1].  You could also use the CD Create PID Model (Parallel) with zero wired to the Integral Gain (Ki) and Derivative Gain (Kd).  If you are going to implement this in a Simulation Loop, then all you need to do is use a multiply primitive.
Chris M
(4,054 Views)
