Add zeroes to an array
I need to have an output array in the size of 1000.
I have a 2D input array with a certain row size (say 400 elements). I
would like to add "0" till i recive a 2D array with a row size of 1000.
What the procedure of doing that?
Thanks!
(3,840 Views)
You could create your 1000 x 1000 zero array then replace the first 400 x 400 elements like this
David
Message Edited by David Crawford on 10-07-2006 05:26 PM
(3,835 Views)
Padding (and truncation) is easiest done with "reshape array" (check the online help).
For a 2D array, just do it in a loop. 🙂 (I assume that you want to keep the column size constant).
Message Edited by altenbach on 10-07-2006 11:07 AM
(3,825 Views)
Thanks Dave, Appriciate the fast response!, however Just for the
simplicity of things I would like to rephrase my request:
lets say that i have the following input 1D array: [1, 2, 3, 4]
I need to have an output array in the size of: 10, so i wish to take
the input array and add "0" to the rest of the 6 places. The result i
wish to have will be: [1, 2, 3, 4, 0, 0, 0, 0, 0, 0]
I will do the extrapulation to a 2D array with a 1000 size of the
output array
Thanks again
Amir
(3,805 Views)
Just follow Christian's has suggestion and use Reshape array.
David
(3,803 Views)
