Add waveform unit attribute to plot name in the plot legend?
I'd like to be able to display the unit attribute (NI_UnitDescription) for a waveform on a waveform graph in the plot legend. It looks like the only thing the plot legend displays is the channel name (NI_ChannelName). It's nice to have the separate channel name and units as part of the waveform data so it can be easily stored in a TDM file. Is there a way to get the plot legend to display something other than the channel name for waveform data? I'm using LV 8.2
George
(3,456 Views)
Hi, George.
You can always change the plot name so that it includes a human-readable unit -- IE, name your plot signal 1 (mV) instead of just signal 1. Obviously that's sort of a workaround, but there's no other way to display them on the plot legend. You do have a couple of other options, however -- you could create an XControl with code behind it to create that functionality. You could also just place a few string indicators on the front panel in such a way that they line up with the plot names (and then modify them programmatically).
Sorry I can't give you a better answer! I hope my suggestions help. Have a nice evening.
Sarah K.
Search PME
(3,443 Views)
Thanks. At least I know I'm not missing something obvious.
George
(3,436 Views)
