Add trigger control at example continuous sound input vi
I am new on Labview programming.
I am trying to add trigger control to Labview\example\continous sound input vi but I found that the program will hault or no signal display on graph. Can anyone has any sample program or what's wrong on my vi?
Message 1 of 8
(4,093 Views)
Hi, it seems that you are stopping the task before even starting. From the looks on the code, it would be easier to enclose the Sound Input Read.vi and the Raw Data indicator in a case structure and use a Boolean control to determine when to read or not.
Alejandro C. | National Instruments
Message 2 of 8
(4,081 Views)
Could you give me an example how to modify my vi?
Message 3 of 8
(4,077 Views)
Accepted by topic author survey
Try this one...I think this is what you were trying to do. I already test it and it's working.
Message 4 of 8
(4,067 Views)
It has a blink on the graph when the switch state from off to on. Is that possible to prevent?
Message 5 of 8
(4,059 Views)
Right click on the graph and select "Ignore Time Stamp"
Message 6 of 8
(4,053 Views)
It does not work.
Message 7 of 8
(4,046 Views)
Try this instead: take the graph outside of the case and do the same changes shown in the picture attach. The blink on the graph is the data updating in the indicator. The suggestion smooths this operation. I hope this helps
Message 8 of 8
(4,025 Views)
