Add timestamp to multicolumn listbox
Hi, I am using LabVIEW 2019. Is there a way to add the timestamp (as a string) in the first column of a multicolumn listbox?  (see the attached vi)
(1,717 Views)
Hi Vries,
in a MCL all items are strings, so you just need to set the first item with your timestamp string…
(1,697 Views)
I added the timestamp but I do not see what I did wrong. The timestamps are written down horizontally.
(1,679 Views)
Accepted by topic author Vries
You aren't building the array the correct way.
You are building times into a single row by storing them in a shift register.  Then Building the other data onto it.
Store the final string array in the shift register.  Build the new data on with the timestamp in the same row as the numeric data.
(1,657 Views)
Thank you GerdW and RavensFan!🙌
(1,621 Views)
