Add text string to a textbox that already exists in a Powerpoint Template
Didnt quite work:
The slide I am adding strings to look like this:
Characteristics
 -Name:
 -Number:
 -Version:
Status
 -Stat1
 -Stat2
and so on......
 method 1 add the string to the last line in the textbox, method 2 seems like it would copy everything in it... but I want to choose the bullet or line i want to add the string to, if that's possible
Message 11 of 17
(1,727 Views)
If it is all in the same TextBox you should use string functions.
Ben64
Message 12 of 17
(1,724 Views)
Thanks alot for the reply.. Although that works but it also change the font style of all the prefilled strings to bold and change all sub-bullets to primary bullets...I'll see if I can fix that
Message 13 of 17
(1,720 Views)
Unfortunately.. I cant seem to find a way to make the bullets and subbullets remain the same when I copy the text back in the textbox
Message 14 of 17
(1,704 Views)
Can you share your slide.
Ben64
Message 15 of 17
(1,701 Views)
Here's the format
Message 16 of 17
(1,691 Views)
The TextRange.Replace method will not change the formatting.
Ben64
Message 17 of 17
(1,687 Views)
