Add output or input to SubVi
It would be better if you post your code or snippet.
-You need to add the input in subvi follow this : http://zone.ni.com/reference/en-XX/help/371361M-01/lvconcepts/building_connector_pane/
uday
Message 11 of 12
(2,830 Views)
@SVP1 wrote:
But what if the input is not in the front panel of the subVI ? I want to connect a wire from the VI as input in the subVI.
It has to be on the front panel on the subVI in order to be connected to the connector pane (which dictates your inputs and outputs).
Message 12 of 12
(2,824 Views)
