Add or delete from array base on a condition
Hi
I would like to add an element to an array if a condition is true.
For example in the attached picture, I would like to add one entry to array when the first element is yes, but I would like to add nothing if the first element is not yes
could you please let me know what should I add to false structure to not add any entry to array. I see if I use defualt value or defualt constant it still adds 0,0 to array
(3,194 Views)
do you have LV2013?
If so, you can use the new conditional tunnel output:
https://www.ni.com/docs/en-US/bundle/labview/page/conditionally-writing-values-to-loop-output-tunnel...
http://www.medicollector.com
(3,179 Views)
@josborne wrote:
do you have LV2013?
This is present in 2012 also.
Bill
CLD
(Mid-Level minion.)
(3,171 Views)
The conditional indexing came out with LabVIEW 2012.  That is the easy way.  If you are using older, then you need to use a shift register to hold your growing array with a Build Array inside of a case structure.
(3,167 Views)
I was too slow...
Jim
(3,162 Views)
Move that equals outside the loop (the optimizer probably does it anyway but, we should point out equals works with arrays)
"Should be" isn't "Is" -Jay
(3,147 Views)
