Add label on y-axis and x-axis in excel using Report Generation toolkit
I want to add label in x-axis(Date/Time) and y-axis(Temperature O=oC)
There are only header and data array connection, how can i add label to the chart?
Thank you.
(2,768 Views)
The way I've done this is by specifying the string inputs named "Column Header" and "Row Header" on the Excel Insert Graph.vi. This should provide the axis labels that you specify on your graph.
Cheers,
Emilie
(2,750 Views)
