Add array to report without timestamp
I'm trying to use the Report Generation Toolkit for Office to form my excel report.
I have an excel template which I am accessing via the Report Generation vi in order to pass a 2d array of doubles.
The array is passed into the report, however, the vi seems to add a timestamp column.
Is there a way to prevent the vi from adding this timestamp.
Thanks for any help you can give me.
(2,662 Views)
Accepted by topic author sinkovich
If anyone has the same problem, I've just found that if you convert the 2d array into 2d array of strings then the vi no longer adds a timestamp.
(2,658 Views)
