Add a word to each loop
I have a problem. If I wanted to put every state of an enum in a string but without overwriting it, how should I do it?
In short, at each step of the state of an enum the state is added in a string and each word must be below the other.
(3,259 Views)
Assuming you're doing this in some loop you can simply connect the state to the border and build an array, then convert this to a string. Enum can be converted to string with Format into string.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,228 Views)
Hi Yamaeda,
Yes, I did it but the previous word overlaps me every time. I need a string that marks every step without eliminating any state.
(3,205 Views)
"overlaps"?  Do you mean overwrites?
Attach your VI.  My guess is you are not using a shift register and a concatenate function when you should be.
(3,139 Views)
An enum and a string are very different things. An enum also does not have a state, just a value. What do you want? An array of strings representing the item names? A scalar linefeed delimited string? Something else? A list of all item names? A log of item names in the order they occur in your state machine?
(3,125 Views)
(3,112 Views)
I notice that sometimes I don't ask the right question, my little experience in programming makes me ask too general questions.
I have 1 and a half of life on labview and 3 months in programming in general.
Yes, I needed a register of the names of the articles in the order in which they occur in the state machine placed inside a string.
Thanks 🙂
(2,977 Views)
