Add a stop and error message to code
I'm slowly starting to understand Labview. I have a working VI. I wanted the VI to not run and display an error message if the user input bad control values.
For exemple, for the number of point, he writes -2, which would make no sense. I would want my VI to not run the rest of the code and have a message display ''Value X is invalid.''
How do I do that in Labview?
Thank you.
(4,153 Views)
Hi Raphael,
how would you do that with any other programming language?
IF value <= 0 THEN
  DialogBox("invalid data input!")
ENDIF
You need a comparison, a case structure and a OneButtonDialog…
But: LabVIEW allows you to set input/value ranges for each numeric control! Configure those controls to not even allow the user to input bad values…
(4,149 Views)
Accepted by topic author RaphaelMT
The best way is to use the error wires. What you need to do is:
  1. Detect the error - You can do this using comparisons (greater than / less than) in your case, but it will depend on your scenario. You can also do it using a case structure, in my example I said that the values 1 through 100 are valid, everything else (default) is not valid.
  2. Trip the error - there are many ways to do this, including a simple cluster bundle, but I like to use the "error cluster from error code" VI, which makes it very easy to see what you are doing. Give it a meaningful message, and stick to the custom error codes range.
  3. Skip any code that doesn't need to be run - You can do this by putting a case structure on the outside of it and making the error wire select the case. This is why a lot of SubVIs have a case structure around them.
  4. Display the error - You can do this with the Simple Error Handler.
(4,148 Views)
