Add a Lego NXT VI to a project and compile it into an executable file
Hi everyone,
I'm trying to find a way to control a lego NXT motor via PC. I tried to create a simple NXT VI that turns on the motor, makes it spin for a second and then turns it off. I used this VI as a subVI for another one that simply execute it. Luckily when I started the top level VI, the motor moved without any problem, but when I created a .EXE file from the project in which these two VI's where included I found out that it didn't work, even if the .EXE creation worked fine. Is there any way to create a stand-alone application that communicates with a Lego NXT controller?
I hope that the question is clear.
Thank you all in advantage.
Lando
Message 1 of 1
(2,382 Views)
