Add For Loop into XY Graph to update the graph display with new datasets
Hi Altenbach,
please refer to my new post, https://forums.ni.com/t5/LabVIEW/Pointer-slide-controls-to-select-iteration-numbers-of-data/td-p/375...
Really need your help, thank you.
Message 11 of 14
(760 Views)
(There is no need to attach the same files as you already did in the linked thread. That only cause confusion)
Message 12 of 14
(753 Views)
sorry for that, I accidentally attached it here in the same post. Hope you can look into the new post in the link given..
Message 13 of 14
(742 Views)
Here is my solution (2 years after):
The key points are to use 2D arrays for X and Y values which are updated in each iteration. Also to use the express XY.
Message 14 of 14
(694 Views)
