Add Columns of Array
You are saying that there is ERROR  when the dimentions are not the same, in the other hand, you are saying it takes the larger dimension for devision.
these two sentences are not the same.
Could ypu please tell me the name of new blocks in your design? I do not have labview version 14.
Message 21 of 47
(1,556 Views)
your design is WRONG. where is N in the for Loop connect to?
Message 22 of 47
(1,543 Views)
Why would you possibly want to wire anything to the N terminal? Don't you know about auto-indexing? Have you taken any of the free tutorials?
Message 23 of 47
(1,534 Views)
Let me also add that you are very rude to yell at someone that is trying to help. It is your lack of knowledge that is the cause of your not understanding and the code is just fine.
Message 24 of 47
(1,529 Views)
I am not yelling. If you think that I am yelling , look inside your self. I just asking questions. at least I did not use worlds like rude or sth.
If you do not want to answer, just do not answer but your behviour is not correct.
The proposed design is not working, That is all.
Message 25 of 47
(1,513 Views)
The use of all caps as your use of WRONG is taken to be yelling. That is the rude behavior I was pointing out and for which you have not apologized. You haven't apologized for spamming the boards with so many posts, either.
Message 26 of 47
(1,506 Views)
I did not know that that Capital means Yelling. If I get correct answer, I do not ask the same questions. what should I aplogize you when you use bad worlds and you tell the others not answer my questions!!!
I just said I tried all of them and still it is not working.
Message 27 of 47
(1,496 Views)
You have not said why the posted code is not working. You only said that N is not wired and I said N is not supposed to be wired.
Message 28 of 47
(1,488 Views)
So what does this problem have to do with adding columns to an array?  People are going to get really confused when they read this thread later.
Anyways, maybe I'm just over simplifying the problem, but why not just use the Mean function?
GCentral
Message 29 of 47
(1,450 Views)
I just found this to convert 1 dimension array of U8 to array of Boolean. If I add this part to my block it should work.
But there is problem in this block which the order of the bits should reverse. Some one have any Idea?
BR
Message 30 of 47
(1,440 Views)
