Add 3 zero after every n element in an array
Hi, I have an array that has 50 elements ( 0 and 1) . I would like to add 3 zero after every 5 elements . As below for the first 10 elements
10101010111111101001 should become  10101010110001111101001000
could you please help me on this one ? I would greatly appreciate if youd attach the code for it
thanks
(2,778 Views)
This seems to do it.  If you have an older version of LV which does not have the Concatenating Tunnel option, you can concatenate with Build Array.
I used controls for the Interval and Number of Zeros to make it more versatile if you ever need to change the parameters.
Lynn
(2,758 Views)
Isn't For loop better choice...??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,740 Views)
Approach with for loop 😄
(2,726 Views)
