Adaptive Filter in LabVIEW 2015 Embedded Control and Monitoring Suite
The Adaptive Filter toolking can be downloaded as part of LabVIEW 2013, as a demo.
It has since been rolled into the Real-Time DSP suite of LabVIEW 2015 Embedded Control and Monitoring Suite.
We have purchased the LabVIEW 2015 Embedded Control and Monitoring Suite, however, none of the Adaptive Filter examples/code work in 2015.
Do you have any suggestions how to proceed?
Thank you.
Message 1 of 8
(4,608 Views)
What happens that they "don't work"?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,576 Views)
Thank you for your quick reply.
Three things happen:
1. The Adaptive Filters folder simply does not exist in the examples folder for LabVIEW 2015. We have tried completely installing/upgrading everything recommended by the embedded update service.
2. Trying to open an example from a LabVIEW 2014/examples/Adaptive Filters folder gives this error:
"NI LabVIEW Adaptive Filter Toolkit for LabVIEW 2015 is missing."
3. Trying to use the 2013 Adaptive Filter Toolkit Demo throws a licensing error, as we do not have the 2013 license.
I've attached a screenshot of the License Manager. It looks like the right license is activated.
Message 3 of 8
(4,551 Views)
This sounds like something to talk to NI about.
Mike...
LabVIEW Champion
Message 4 of 8
(4,539 Views)
Firstly, it would be best to remove that image from your post as it has your serial number.
Secondly, I noticed you don't have the Digital Filter Design Toolkit, which is actually what the Adaptive Filters Toolkit got rolled in to. Go ahead and download this toolkit and see if you can find the files you're looking for.
Best,
Mathew H.
Message 5 of 8
(4,507 Views)
Thank you for your repplies.
I'm going to mark this as closed. I have completely uninatalled LabVIEW and am doing a clean install.
Message 6 of 8
(4,487 Views)
I would be grateful if you know how I can remove the picture from my previous post. You make a very good point about the serial number.
Message 7 of 8
(4,485 Views)
I reported the post to a moderator, and it may take them a little bit to get to it. Hopefully they will see it soon.
Mathew H.
Message 8 of 8
(4,458 Views)
