Actor Framework Packed Library dependency
I have build a Actor Framework project that works fine. For better maintenance I build packed Libs from different Actors like
setting, save data... This works also great.
The device Actor is dynamical loaded depending of the device type (PlugIN Architecture). I is also working correctly.
But because the Device class contains a lot of different children (devices). It is very big.
The goal is to septate the Low Level Device class into a few packed library.
The Development System would be much faster. And the EXE does not contain all PlugIn Devices. It should be possible
to put just the needed device into the Application.
But I don't now that is the best way to separate this actor into different Packed Libs.
Does any body have a idea?
Class hierarchy is attached.
(2,355 Views)
Accepted by topic author bodo_online
The solution is to implement a interface class between the real device and the actor.
This interface is not a child form the actor framework.
(2,311 Views)
