ActivexWord_Error
When i tried to run the attached activexword.vi, i got the following error. Please help me in this regards.
Error -2147352567 occurred at Unknown
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
Also I want to write some data to word document at specified location. Can you let me know, is there any library function for this.
Regards
Shivakumar Singh
(2,546 Views)
It works here, with LV 7.1 and Office 2003...
In attach I send you an example where it writes in a new Document some txet in the beginning. You could change the position in the range.
Hope it helps,
Paulo
(2,542 Views)
