Activex problems
This one was submitted to Ni guys but if you've any idea...
I'm currently writing an app which should display a nice graph (chart) on
its front panel. I choose to use MSGraph8 ActiveX from Microsoft, which is
furnished with the Office suite.
To do this, I've placed a container on my front panel, and in the window
'select activex object', I'm going to the 'Create Object' item in the
droplist and choose "Graphique MS Graph 97" (in french).
It works quite well, but :
1) It seems creating this document launches MSGraph8, as I see in the task
list when ctrl-alt-deleting; and that this Msgraph DON'T CLOSE when closing
the VI !! In other words, after some time, the VI hangs. I need you help
please ! How do I close this Msgraph ? I hop
e it's possible.
2) Using the properties & Method, I manipulate this object. Some Properties
return an object, which I use to define properties of this new object, ok ?
The problem is that some _Methods_ that should return an object refnum
returns a variant ! I tried to use the "To G data" function, but it can't
help. What should I do to convert this variant to an object refnum ?
I send you a copy of my VI, with some comments inside it. Thanks for your
help.
PS/ I'm french speaking if you want.
Matthieu Gaillet MGaillet.ccrm@euronet.be
Technicien R&D
C.C.R.M
Rue des Belles-Pierres 5
1421 Ophain
http://users.skynet.be/ccrm
[Attachment Occupation - Dépouillement.zip, see below]
[See first answer for additional information]
(4,347 Views)
[Attachment(s) for question]
(4,347 Views)
I looked at the VI you provided and was able to correct the problem. Since the Method Chart Axes
has 3 options of what to return, the return type has to be a variant. I just clicked on your
automation refnum above the Convert To G function and selected Graph.Axis (Microsoft Graph 8.0 ->
Axis). That is the desired return type for the xlValue selection. The Property control wired to
the Convert then showed the full range of properties.
-Michael
Michael Munroe Mailto:mmunroe@abcdefirm.com
A Better Complete Development Engineering Firm
San Mateo, CA 94403 http://www.abcdefirm.com
Get shirts at http://www.stitchofclass.com
Get Clarity at http://www.symmcorp.com/mmunroe
Matthieu Gaillet wrote:
> Hello,
> please ! How do I close this Msgraph ? I hope it's possible.
> help.
> Technicien R&D
> C.C.R.M
> 1421 Ophain
> Name: Occupation - D�pouillement.zip
> Occupation - D�pouillement.zip Type: Zip Compressed Data (application/x-zip-compressed)
> Encoding: x-uuencode
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(4,347 Views)
Thank you really for your help ! It was simple... But not obvious ! 🙂
I'll try this & tell you if it ok.
MG
Michael Munroe a �crit dans le message :
39490EFD.65709935@abcdefirm.com...
> -Michael
> > Hello,
on
is
task
closing
Properties
ok ?
can't
your
> > help.
> > Technicien R&D
> > C.C.R.M
> > 1421 Ophain
D�pouillement.zip
(4,347 Views)
MS Graph has method Quit so you might try invoking it after modifying graph
to stop MS Graph from running.
"Matthieu Gaillet" wrote in message
news:3949c98a@newsgroups.ni.com...
> MG
Graph.Axis
> > -Michael
> > > Hello,
> on
which
> is
window
> task
> closing
help
> Properties
> ok ?
> can't
> your
> > > help.
> > > Technicien R&D
> > > C.C.R.M
> > > 1421 Ophain
> D�pouillement.zip
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(4,347 Views)
To get objects refnum to be connected to the conert to G data do following:
1) Create a new ActiveX refnum control on the front pannel
2) Right click, and go to browse and search for MS Graph Object Library
3) Once you pick it, selection box will be empty, so uncheck "Show Creatable
Objects only" box
4) There should be an option to select Axes object.
Why it keeps on running I have no idea since I cannot run your example, I
have newer version MS Graph, and wires are broken, and I am too lazy at the
moment.
Reinis Kanders
news:3948a3f4@newsgroups.ni.com...
> Hello,
closing
Properties
> help.
> Technicien R&D
> C.C.R.M
> 1421 Ophain
(4,347 Views)
Exactly the answer of the NI support ! Well done. Thanks you for your help !
MG
Reinis Kanders a �crit dans le message :
39492291_4@goliath.newsfeeds.com...
following:
Creatable
> Objects only" box
the
> moment.
> Reinis Kanders
> > Hello,
on
is
task
> closing
> Properties
ok
can't
your
> > help.
> > Technicien R&D
> > C.C.R.M
> > 1421 Ophain
(4,347 Views)
