Activex Problem
I use the OPEN Automation and at the end of Vi i close the Automation. Is that correct?
Sometimes i 've problems to open the automation.
What can i do to fix this problem.
please help
H.A. Brosi
(3,201 Views)
Hi H.A.,
Make sure to close ALL references that you open during your VI and do it in the reverse order of how they were opened.
Forgetting to close all references, or messing up the order of closing, is a very common programming mistake, that most likely will give you errors.
Philip C.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,201 Views)
Thanks Philip C.
Do you have any examples about labview activex prgramming?
To show the correct way of programming activex components.
best regards
H.A.Brosi
>>> Philip C. 22.10.2004 05:23:57 >>>
Hi H.A.,
give you errors.
Philip C.
(3,201 Views)
H.A.
Please visit our resource for ActiveX related material here: http://zone.ni.com/devzone/devzone.nsf/webcategories/9C6DF90777E5A78206256874000FA14E
Here you can find tutorials, example programs and much more�
Philip C.
Thinkbot Solutions
(3,201 Views)
