ActiveX strange behaviour
As somebody recommended, I used ActiveX to implement
animated gif-s, but now I have a problem with ActiveX
container. When I put a container in the front panel, and
select the ActiveX Object, the container starts to behave
strangely, it becomes in a kind of front panel clone, what
I meant to say is that if I move the cursor inside the
container to the top left, the cursor changes and if I hit
cursor button, File menu opens. I can access all menus from
the activeX container! Is there any solution?
Thanks in advance
Gorka Larrea
glarrea_1@hotmail.com
* Sent from AltaVista http://www.altavista.com Where you can also find related Web Pages, Images, Audios, Videos, News, and Shopping. Smart is Beautiful
(2,811 Views)
Try using Microsoft Web Browser as the active X container. It too can run
animated GIFs.
-Jim
Gorka Larrea wrote:
>As somebody recommended, I used ActiveX to implement>animated gif-s, but
now I have a problem with ActiveX>container. When I put a container in the
front panel, and>select the ActiveX Object, the container starts to behave>strangely,
it becomes in a kind of front panel clone, what>I meant to say is that if
I move the cursor inside the>container to the top left, the cursor changes
and if I hit>cursor button, File menu opens. I can access all menus from>the
activeX container! Is there any solution?>Thanks in advance>>Gorka Larrea>glarrea_1@hotmail.com>>>*
Web Pages,
(2,811 Views)
