ActiveX refnum custom probe as numeric
Hi all,
   Ok this may be simple or impossible but I can't figure it out.
When you probe an ActiveX refnum wire on the diagram, it shows as a unique number (or 0 if its not valid).  This is useful if the refnum changes (like stepping thru a XML file using DOMDocument)
   However when I tried to do a custom probe, the probe shows up as the refnum control icon so you can't see a number.  This doesn't help me.  I tried changing that control in the custom probe to a numeric but it breaks.  (actually when I tried to use a numeric array as the custom probe in LV2010 for a refnum array, it gave me a message about incompatible type and then it crashed)
  Is there a way to show the number of the refnum in a custom probe?  I guess that would be the same as showing the number instead of the control on a regular front diagram, so maybe it has to be separated out first but how does the simple builtin probe do it?
On a side note, using the Probe Watch Window, for 1D or 2D arrays, the Probe Display just shows a single element.  Is there a way to expand the array to show more than 1 element in that window? The values are all shown on the left side in a single line but with 2D arrays especially its hard to see where the next column starts.
Thanks for your help.
(3,050 Views)
Accepted by topic author TS9
TS9,
Please refer to the following Knowledge Base when attempting to display a refnum value in labview. Using type casting to U32 I was able to extract the refnum number and output to a indicator using the following code. I had to make the display format for the indicator hexadecimal; you can do this by right clicking the indicator and clicking display format.
You can use this idea when you create a custom probe. Make sure you select "new.." custom probe (and select new probe). This will create a vi with a block diagram and front panel. You could create a custom probe that does the same as this indicator.
Hope this helps.
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
(3,029 Views)
Cool.  That works great.  Thanks.
(3,011 Views)
