ActiveX object preset properties.
Hi, all,
I was trying to use ActiveX container with an ActiveX object to control one of our equipment, to be precise, the Newport FTIR: http://www.newport.com/8035-Series-FT-IR-Scanner/1035143/1033/info.aspx.
The problem I have right now is whenever I just open the vi with ActiveX object, it seems that the device receives some property settings which will make the device stuck(some sort of bugs in the Activex driver). So I wonder if there's any way I can change those presettings of the ActiveX object properties in Labview?
Wan
(2,811 Views)
I am not certain that you can change the loading properties in LabVIEW, you can certainly change properities after using property and invoke nodes. Have you tried reinstalling the driver? You may need to contact Newport to learn more about the initialization.
Michael Bilyk
Former NI Software Engineer (IT)
(2,769 Views)
