ActiveX control error
Hello, when I try to use ActiveX in Labview 2018 (the first attached png file) and the error shows up (the second png file). I found some of ActiveX selections work fine, but some not. Is there any compatibility issue between Microsoft control and Labview in Windows 10?
Thank you very much!
(2,698 Views)
Hello AllenIMCORP,
This is a problem with the licensing of certain Microsoft Visual Basic 6.0 controls.
Please take a look at these links:
https://forums.ni.com/t5/LabVIEW/MSComDlg-ICommonDialog-quot-Class-is-not-licensed-quot-error-in/td-...
https://support.microsoft.com/en-us/help/318597/you-receive-an-error-message-you-do-not-have-a-licen...
Hope this helps!
(2,664 Views)
