ActiveX control and Mapping Data.
Hi all,
I'm using GDK tool kit to display map data . with using MapView control and use Propertiy node and Invoke node but he doesnt work as I expected.
Who can help me?
(2,553 Views)
Hi Kim,
I'm not sure what you are trying to do. Can you explain how you are calling the control or property nodes? You can attach your code if it helps.
I was unable to open the files you attached. What are they written in?
Sappster
(2,492 Views)
