ActiveX: Picture property
I would like to load a picture in an ActiveX control by the Picture Property. How you do that ???
(2,973 Views)
I attached vi that use Microsoft Picture Clip ActiveX.
It have picture properties where you go to browser and select some picture.
(2,973 Views)
Previous zip file was bad.
Click to this zip-file.
(2,973 Views)
Thank you for this first answer, but I believe that I was not suffisament clearly in my question. I wish used a ActiveX control as grid control which has a property which is called picture that I will want to initialize by programming, this starting from file name image.
The property picture calls upon several properties like Handle, type, hpal... and the method render.
How starting from a file name, can I recover all this information???
(2,973 Views)
