ActiveX Access Linked Table
I am trying from Labview to create a link to an external table in an MS Access database. The code example hereafter should illustrate my goal:
ActiveX table link attempt.jpgMy problem is apparently when I want to append the newly created link: passing a reference to the TableDef 'Append' method doesn't work.
Does someone know how to work around this -- is there any way to convert properly the tabledef item?
Thanks in advance for any feedback.
Andre
(3,598 Views)
Hi dederocks,
to connect to a MS Access Database you have two possibilities:
- work hours and hours to do everything on your own with ActiveX like you try at the moment, but I think you need a deep knowledge on how to program ActiveX Properties and Invokes from the MS Access Database. It's very difficult and perhaps you ran from one issue into another.
- puchase or organize the LabVIEW Database Connectivity Toolkit:
http://www.ni.com/pdf/products/us/6774_database_connectivity_toolkit.pdf
with this Toolkit you get a API to easy connect to almost any database. Also there are a couple of examples integrated to the toolkit, which help you.
If I where you, I would check the link and check if you have already the DBC-Toolkit in your company, if not I would call your NI Representative.
Best regards
Alex Rudolph
Support
NI Switzerland
(3,561 Views)
Hello Alex,
Thanks for the feedback. Actualy, I considered purchasing the Database conectivity toolkit, but as far as I could read in the NI documentation, it is NOT able to do what I was asking for -- namely, create in an Access DB a link to an external table in another DB. Or am I wrong?
Best Regards,
André Lehmann
(3,556 Views)
this was not clear at all from your first entry. I will check this out and answer as soon as I have a response from our Headquarter in Austin.
Best regards
Alexander Rudolph
(3,553 Views)
Hi Raffael,
the feature you would like to have is not implemented in the DBC Toolkit, you can manipulate anything but data in a database (i.e. create tables, add data, retrieve data). DBC can also get and set database "properties" but I don't believe that creating a link to another database can be considered a property -- it's more like an action.
This means you`re on the right way, when you use the Microsoft Access Invoke Nodes. Because I don`t have a Access License here, it becomes difficult for me now. The first step in your code I would do, is to implement proper Error Handling and check if you get some error codes. As long as you say it is not working at all, we can`t focus on anything.
Best regards
Alex
(3,539 Views)
