ActiveSync for PDA module
Is there any way to ActiveSync PDA to Host by USB or Ethernet? Serial
is too slow! and Download takes too long time!
(3,945 Views)
Currently, the only supported method is via serial. But, you should be able to copy over the executables by any method as long as you do it manually.
But, you can only do debugging via serial. So, you would be downloading via USB (or ethernet if you have the capability via another method), but you will still need a serial connection for debugging.
(3,945 Views)
It depends on your cradle. My iPAQ H3950 has both a serial and USB connection.
(3,945 Views)
