Active noise control example code
Hello!
I am trying to implement the example code for Active noise control in LabVIEW on a experimental setup with two speakers and a microphone. I need help in the setup conditions (distance from speaker to speaker) and also I am using TEDS sensors so I need to add the TEDS sub.vi into the code. Has anyone conducted such an experiment using the Active noise control example .vi?
Thank you!
(2,428 Views)
I hope you're talking about the cRIO example because the other one is just a simulation.
In that case, the documentation of the VI specifies how to space the speakers and microphone, HW requirements etc.,
Santhosh
Soliton Technologies
(2,392 Views)
Dear Santhosh,
thank you very much. You're right, I am talking about that example. I have placed the hardware right, but I was wondering how "small" is several centimeters in distance between the speakers and also, should the zone between the speakers be isolated totally from the environment. I am asking this because according to the literature references I have used in active noise control in experimental ducts, all the examples are conducted in ducts with length around 1 meter and isolated. Also, I am using TEDS sensors as sound sensor and I am having concerns if the TEDS .subvi is correctly connected and implemented into the host.vi. Would you mind taking a look into my project and see if you find a mistake somewhere, because somehow I don't happen to obtain noise cancellation even though the FPGA .vi is correctly compiling and the host .vi works fine.
THANKS!!!
(2,370 Views)
