Active X database querying problem..
Hi
i've downloaded a active X example (that you can get from
http://exchange.ni.com/servlet/com.quiq.servlet.GetObject/activexdb.zip?KEY=
101.97.18400.14&SIG=101.97.18400.14&EXT=mime:application/x-zip-compressed),
but i can't get it working.
All i have done is extracted the contents of the zip and loaded the active x
example. Both the database and the vi are in the same folder. I haven't
changed anything else.
But when i try to read/insert/update values in the table it comes back with
the following error:
Exception occured in DAO.Workspace, ODBC--call failed.. Help Path is
jeterr40.chm and context 5003146 in Number or Rows.vi
i don't know what this means and have no idea of what to do next, i don't
suppose anyone could help?
thanks a lot
D.
(3,562 Views)
On Sun, 24 Feb 2002 21:11:48 -0000, "D"
wrote:
>Hi
>thanks a lot
>D.
If my memory is correct, that example was written for Access98.
I have an example using ADO and Access2000 at work.
Email me at LKuo@multiplexinc.com
(3,562 Views)
D -
Check out LabSQL: http://www.jeffreytravis.com/lost/labsql.html
It uses ADO to connect through ODBC. Here is the first paragraph from their
readme file:
"LabSQL is the beginning of an open source project to provide free,
multi-database, multi-platform database connectivity support for LabVIEW.
In this first release, we have used the Microsoft ADO object to provide
connectivity in LabVIEW for Windows for any ODBC-compliant database,
including Access, SQL Server, Oracle, Pervasive, Sybase, etc."
Brian
D wrote
> Hi
sed),
(3,562 Views)
