Active X between LabView and Lotus 1-2-3
I want to controll Lotus 1-2-3 with LabView using Active X.
I have tried the example: "Write table to Excel.vi", and it works.
But When I try to do a simular opperation against Lotus it fails.
When i select the ActiveX library: "Lotus 1-2-3 Versin 1.0" there are no creatable objects. When i remove the selection on :"Show creatable objects only" are the objects simular to the objects when Excel-Library are selected. But when used they don't work.
(2,729 Views)
Try selecting "browse" when you are prompted for an activeX object, and select the Lotus 1-2-3 activeX library from it's directory. If 1-2-3 is properly installed on your system, you should be able to create objects using it's activeX capabilities. If browsing does not work, I'd try installing Lotus again. I'd be glad to help you, but don't have Lotus 1-2-3 so... Good luck.
(2,729 Views)
