Acquiring 2 analog input signals simultaneously using 1 express DAQ assistant
I am using a NI DAQCard-6062E with LabView 8.2 to aquire 2 analog voltages but I can only see 1 data output on my DAQ assistant (shown as the bottom DAQ assistant in the screenshot.  The other DAQ assistant is for a separate card which is working just fine).  I have configured the DAQ assistant to receive 2 voltage signals from 2 capacitance probes as shown in the 2nd screenshot.  The one voltage being outputted from the DAQ assistant works just fine, but I can't find a way to get the second data output.
(2,973 Views)
Posting a word doc instead of the actual VI doesn't help much. If you want to just post images, post them directly instead of putting them into a another file and then posting that.
If you truly have 2 channels configured in the DAQ Assistant, then you need to use the split signal function to get the separate channels before you wire the dynamic data to different scalar indicators. The graph indicator should be showing the different channels though. If it's not, then you don't have the DAQ Assistant configured correctly.
(2,950 Views)
I actually figured that out yesterday but forgot to post again, but thanks for your help.
(2,945 Views)
