Acquire single analog point on each pulse
I have a query on what i hope is a simple application. Im using a PCI-6220 card and what I would like to do is aquire a single data point which is to be triggered by a digital pulse. The pulse will come from an encoder, and what I would like to do is aquire a single analog data point each time the encoder channel pulse goes high (retriggerable daq?)
Which would be the best way to approach this?
David
(2,634 Views)
David,
this is easily done by importing your encoder-signal as external clock for your AI (which is either finite or continuous then!)
hope this helps,
Norbert
[EDIT]: This will work out directly if the encoder creates CMOS/TTL pulses. If it doesn't, you should consider some kind of signalconditioning for your encodersignal
Message Edited by Norbert B on 11-19-2007 03:41 AM
Norbert
Expert: Geometry
(2,601 Views)
