Acessing COM Object having iUnknown interface
I have some COM(Component Object Model) components using custom interface
i.e they have been derived from IUnknown and not IDispatch. These have been
created using VC++.
I want to use these components in my Labview project.
How can i create this objects in my application ?
thanks
(2,821 Views)
Either place a ActiveX Container (If your COM Object is a Active X Control) from the "Container" Palette or a Automation Refnum (If your COM Object is a Server Application) from the "Refnum" Palette on the Frontpanel. Now you can make a right-click on these Front-Panel Objects, and select your COM object.
(2,802 Views)
