According to an input quantity, generate the corresponding quantity of the waveform chart
I try to reduced the version of VI to 11.0(here I want to ask LabVIEW will generate the old version of VI in the folder?) .
As you said, I also think my code is too complicated in the implementation algorithm. would you mind providing me some links of relevant LabVIEW tutorials? Thank you very much for your patient guidance ~
Message 11 of 16
(663 Views)
While you probably saved for previous, you still attached the 2021 version. The previous version will be in a subfolder. Saving for a previous version will generate a new hierarchy. It won't overwrite the original of course. That would be very bad!
Have you studied my example above?
There are a lot of learning resources listed at the top of the forum.
Message 12 of 16
(656 Views)
thank you so much! Your program let me benefit a lot!
Message 13 of 16
(654 Views)
I'm so sorry for my fault, I just tried it again.This time I see that the new VI file has gone down from 29KB to 21KB, and I think I have succeeded.
Message 14 of 16
(649 Views)
Some quick hints about your mistakes and unnecessary complications.
(Of course you first need to ensure that N plots exists. You cannot set a property for nonexistent plots. Compare with my code)
Message 15 of 16
(642 Views)
Thanks a lot for your valuable modification opinions! I will modify my program according to your opinions and reference procedures.
Message 16 of 16
(622 Views)
