Accessing cluster elements from a cluster reference
I am passing a cluster reference to a subvi. In the subvi I would like get/change values of individual elements of the cluster. How do I get/change value an element by name? When I use unbundle by name I get wire error.
Thank you.
Girish
Message 1 of 8
(2,550 Views)
You can feed that reference into a property node and use the Value property to read/write data.
Message 2 of 8
(2,541 Views)
When I connect to a property node, I don't get the list of elements in the cluster.
I have elements like baud rate, parity etc. which do not show up in the choice list. What is the property Value anyway?
Girish
Message 3 of 8
(2,521 Views)
The reference is a pointer to some cluster on a front panel. The Value property is the value of that cluster. You should be able to right-click what you have and change to read and then unbundle the Value output of the property node.
Message 4 of 8
(2,512 Views)
You need to use the type def to tell the subVI what's in your cluster.
https://tmesystems.net/
Message 5 of 8
(2,480 Views)
That's true for generalized cluster references, but not for "Strict" references.  It depends on the reference and how it was copied around.
Message 6 of 8
(2,460 Views)
Girish
Change that Value property to "Read", then wire it to an unbundler.
Message 7 of 8
(2,401 Views)
This is a possible race condition though, generally not 100% safe as other code accessing the cluster (read or write) can act on the data in the time period between reading and writing via property node in your diagram.
Message 8 of 8
(2,361 Views)
