Accessing a device property
Greetings!  I am using two different USB devices as virtual com ports.  I would like to be able to see in LV the model names that come up under Windows' Device Manager window, so I can tell which device is currently connected.
I've attached a JPG showing the two USB devices (at the bottom).  You can see the currently highlighted device lists the model name as "FT232R USB UART".  The other device model name will show "USB <> Serial Converter".  However, when I go to MAX and look at all the COM port attribute listing, I don't see the model name anywhere.  How do I access the model name in LV?
(Currently using Win7 and LV 2010).
Amateur programmer for over 10 years!
(3,224 Views)
Oops, I accidentally bumped my thread!
(3,199 Views)
It looks like LabVIEW is looking for the drivers for these devices.
Carl W.
Applications Engineering
(3,177 Views)
Thanks for responding.  LV does see the USB virtual com port devices and I can communicate through either one.  But I would like to be able to identify which device is being used.  When I view the properties I don't see any differences between the two.
(3,174 Views)
Without a driver I do not think there will be a way to send a check to the device.
Carl W.
(3,159 Views)
use the system API
"Should be" isn't "Is" -Jay
(3,156 Views)
I've put in a property node that's looking at the system API, like you have in your example.  However I don't see "Vendor Name" as an option in the list of properties.  Is that a property that's not available in LV 2010?  I'll try "ProdName" and see if that will do the job.
(3,150 Views)
