Accessing DAQ-Card 1200 in LabVIEW?
I configured Daq-Card 1200 in MAX, set the input and output values and so on. How can I now access the card in LabVIEW. Should there be maid any additional configuring under LabVIEW since first time I set up in and out values in MAX there was a place I could set different values to different channels but this time the configuration window lacked many things it used to have.
(2,647 Views)
When you configure the device in MAX, MAX assigns Device Number to the DAQ Cards starting with 1.
In labview you can open up DAQ example and run it by specifying correct device number and channel number from which you want to acquire data. You do not need special configuration in labview.
Hope this helps
A Rafiq
http://www.ni.com/ask
(2,646 Views)
