Access labview controls from external application
Hi! There's an application written in LabView that shows dialog messages with buttons and textboxes. I'm writing a C# application that automatically fills these textboxes and clicks on buttons. I'm using user32.dll functions to find windows and controls, but at Labview's windows I cannot see any controls inside(with spy++ and ui spy). Is there a way to access these controls using other DLL files or sending special messages to the main window?
Tnahks for your help!
(3,291 Views)
LabVIEW does not use Windows controls in its frontpanel, as that would not be portable to non-Windows platforms. So there is no way to do classical Windows handles peek and friends. But LabVIEW allows to control a subset of its VI Server interface through ActiveX.
The application needs to be build with that in mind, and there need to be some settings in the INI file to configure this functionality. Then you can connect to the LabVIEW ActiveX Server and control VIs and also controls to some extend.
Rolf Kalbermatter  My Blog
(3,277 Views)
Functionality provided by LabVIEW as an ActiveX Server
Activating LabVIEW as an ActiveX Server
Christian
(3,265 Views)
