Access database query with SQL vi under LabVIEW 6.1
I am attempting to read details from a Database, (DBMS Microsoft Access 2000) using the SQL attachments associated with LabVIEW 6.1. Despite efforts to configure the correct driver for the database through the Control Panel, each query submitted through the SQL vi. returns the same error. Namely, 'datasource name not found and no default driver specified'. Perhaps you can offer some help.
(3,052 Views)
I have never had this issue before, but I did a search on Google and there appears to be a lot of information on the error "datasource name not found and no default driver specified". Here were the results when I searched for it. You may want to look through these various postings to see if something may be similar to your system.
J.R. Allen
(3,052 Views)
